[Resolved] Trouble playing mp4 video
craigmont
Post by craigmont » Tue Mar 27, 2018 7:30 am
Hello,
mp4 videos will not output audio on my system. Audio cues and .wmv video cues work fine.
diagnostic attached.
scs11diag_2018-03-26_142631.scsz
(49.69 KiB) Downloaded 36 times
Re: Trouble playing mp4 video
Post by Mike Daniell » Tue Mar 27, 2018 9:05 am
From what I can see in your diagnostic file, I presume you have not installed LAVFilters. The easiest way to do that is to re-install SCS and accept the option to run the LAVFilters installer. Then make sure that all the 'Custom' checkboxes are selected except for the H.264 checkbox (as that one requires an extra download and is not necessary). Also make sure that under LAV Splitter Formats (a later dialog window) that MP4 is selected.
craigmont
Post by craigmont » Wed Mar 28, 2018 4:42 am
Thank you for your quick reply.
I thought I had installed the LAVfilters, but I'll try again.
craigmont
Post by craigmont » Wed Mar 28, 2018 6:09 am
I've unistalled, reinstalled, with LAV filters, still can't play mp4 videos with audio.
scs11diag_2018-03-27_130834.scsz
(57.74 KiB) Downloaded 32 times
Post by Mike Daniell » Thu Mar 29, 2018 2:11 pm
Just an update for other users: it seems the non-playback of the MP4 files on Craig's machine was due to some issues with 64-bit video codecs. When running the 32-bit version of SCS the files play perfectly, still using the TVG video playback library.
