11.1.2 Playlist Issue (Bug?) (fix in 11.1.3)
Eric Snodgrass
Post by Eric Snodgrass » Sun Oct 14, 2012 7:02 am
In SCS 11.1.2 editor window, I'm putting together a Playlist cue with many files. After inputting the files, I find I want to reorder the files, which is proving difficult to do. Why?
Well, choosing a file is not as easy as simply clicking on the track or order number. In order to choose the track I want to move I must click on the ELLIPSE box. That brings up an Explorer window, which I close. Once I close the Explorer window the desired track is now chosen and I can move it up or down in the order, but only with the Arrow keys next to the playlist, and that is a lot of clicking when there are 45+ tracks.
I would like to be able to double click on the track and have it chosen so I can then move it. Also, I think a feature that should be implemented is the ability to double click in the No. box of any track in a playlist cue and be able to change the number, thus changing it in the playlist order. That would be a much easier way to reorder a playlist.
Re: 11.1.2 Playlist Issue (Bug?)
Post by Mike Daniell » Mon Oct 15, 2012 11:09 am
This is a bug which occurs if you click on the file name. It's OK if you always click on the 'No." field, but once you've clicked on an "Audio File" field then SCS ignores clicks in other rows.
A fix is ready for the next release.
