Delete Demo and Turn off sounddesk closing warning (in 9.0)
Matt Haggerty
Post by Matt Haggerty » Wed Feb 15, 2006 2:20 am
Hi, is it possible to delete the Demo from within SCS Pro? I notice also with the first project I have started, right clicking does not present a delete option for that either.
Can the pop up "turn off computer channels on sounddesk" warning when signing off be toggled off?
thanks!
Matt
Post by Mike Daniell » Wed Feb 15, 2006 9:08 pm
When SCS starts it will open the last cue file used, and only if no previous file has been opened will it open the demo file. Is that not what you are experiencing? This approach means that when you are developing or running a show, once you have started building your cue file for that show then SCS will automatically open that for you every time the program is started. You should not be seeing the demo file opened unless that was the last file you opened before you last closed the program.
Turning off the final pop-up message is not currently available, but I could implement that in SCS 9. I'll give that some consideration.
