Strange Keyboard-problem on Intel-Macs
MaikW
Post by MaikW » Tue Mar 20, 2007 10:38 pm
We're using Intel-Macs for SCS, one running Win XP natively, one with Parallels.
The problem, I'm reporting, is on both of them.
In our first SCS-"powered" show, there are some wav-files with some manually triggered level-change-cues.
If I manually skip some time of the running sound-file by clicking with the mouse, the first level-change-cue is recalled as expected.
The second level-change-cue is recalled correctly only if I use the space bar. If I use the "Enter"- or "Return"-key, the soundfile fades out totally with the fade out time, which is setup in the sound-file's properties and stops then.
That's not the behaviour, I'd expect!
Can anybody confirm this?
Regards...
...Maik
Post by Mike Daniell » Wed Mar 21, 2007 5:31 pm
Which version of SCS are you using?
MaikW
Post by MaikW » Wed Mar 21, 2007 7:21 pm
9.3.5.
In 9.3.4 it was the same.
Another strange thing:
if I close the editor, the word "Hot Keys" is "highlighted" and seems to be the focused item for both the "Enter"- and the "Return"-keys. -> without clicking somewhere else, no cue is recalled.
Gues what: the space-bar still works, regardless if "Hot Keys" is focused or not.
Regards...
...Maik
MaikW
Post by MaikW » Wed Mar 21, 2007 8:02 pm
And some additional information:
SCS-Professional 9.3.5,
on a MacBookPro, 15", (BootCamp), Win XP Pro SP2 updated,
and on a MacBookPro, 17", (Parallels), Win XP Pro SP2 updated.
As soon as we have another licence for Windows, we'll install on a MacPro too, but that can last some time.
Seems to be difficult for our IT-department to get a licence here in Germany.
Regards...
...Maik
Post by Mike Daniell » Fri Mar 23, 2007 6:35 pm
OK, found that problem. Will be fixed in the next update.
