Fade out others and the mouse pointer.
PeterMount
Post by PeterMount » Thu Oct 28, 2021 8:11 pm
Please could you help with the following:
1. I've searched but can't find the switch to stop "fade out others" on lighting cues. I'm trying to avoid having to re-enter already running cues every time I start some more lanterns.
2. If my mouse cursor accidentally goes off screen right it shows up on the projected image on stage? Is there a way to fix this in SCS, or is it how my compter is set up?
Many thanks.
Re: Fade out others and the mouse pointer.
Post by Mike Daniell » Fri Oct 29, 2021 10:20 am
1. Re "fade out others", please email me your cue file (the .scs11 file).
2. Re mouse cursor control - unfortunately I'm not aware of any way to prevent the mouse pointer from moving to a screen.
Nino
Post by Nino » Fri Oct 29, 2021 6:12 pm
I use Dual Monitor Tools (http://dualmonitortool.sourceforge.net/index.html) which allows you to lock the mouse cursor to a particular screen and prevents the cursor moving onto the projection screen.
Post by Mike Daniell » Sat Oct 30, 2021 9:02 am
Thanks for the log file. Regarding "fade out others", you just need to set 'fade out time for other active channels' to 'do not fade out others'. I've emailed you a screenshot example for one of your cues.
PeterMount
Post by PeterMount » Sun Oct 31, 2021 5:02 pm
Thanks for telling me about toggle for fade out others. Rather obvious I guess, but I'm still learning!
And thanks too Nino re the pointer.
Cheers,
Peter
howartp
Post by howartp » Sat Feb 26, 2022 8:27 pm
Was about to post about DualMonitorTools.
The other option is to move your second screen in Display Settings so it’s aligned diagonally - then the only way between screens is to move mouse to that corner. Top-Left would be my favourite as less likely to be hit, and similarly bottom-right of the second screen would be the escape back to screen 1.
