Overflow error in Editor (fix in 10.1.2)
Post by Mike Daniell » Sat Aug 23, 2008 6:31 pm
Nick and frfortes have both reported overflow errors when adding files in the Editor, but I hadn't been able to reproduce the error until I stumbled across it today. The error occurs if you add the same file twice, either as two sub-cues or as two cues. A fix will be issued shortly.
frfortes
Re: Overflow error in Editor
Post by frfortes » Sat Aug 23, 2008 9:28 pm
Now that you mention that, I remember that I was adding a subcue with the same file. The loop error points that I reported to you happened also when I added a cue with the same wave file as another cue.
Cheers!
Fernando Fortes
