Post
by Mike Daniell » Thu Aug 21, 2008 4:00 pm
I've had an interesting email from Dee that says in part:
"I have been playing around with SCS and discovered that it
will quite happily play flash animations once the abobe flash plugin is loaded onto your machine
. Note I have to set *.* in the video file selection box first as its not in the list of allowed video formats. You get the audio from the flash as well."
Note Dee's reference to using *.* in the file selection. The video formats supported are limited only by installed CODECS and what Windows Media Player can handle. I haven't tried the adobe plugin, but it may be that installing the plugin also installs a suitable CODEC. Anyway, as long as it works that's all that matters! Thanks, Dee, for the info.
DumaisAudio
Post
by DumaisAudio » Tue Sep 16, 2008 5:10 am
Has anyone used SCS 10 to do playback of .mov files (Quicktime), and if so, were there any issues? We're looking to upgrade to version 10 and consolidate our projection playback into SCS, but our video person uses a Mac and renders video into Quicktime. I'm assuming there is a Quicktime codec for WMP? Thanks
