Hello!
I’ve been testing a new copy of SM-S with SCS and found what I think is a couple bugs.
Using version 11.9.8
1. Cues with a Cue Marker as the activation trigger don’t trigger when using SM-S. If I changed the device back to just Direct Sound or ASIO (using BASS) the CM auto trigger works fine.
2. Stereo files that are played to a device that is only a single channel seem to overdrive the device with distortion. I can see in the SM-S Monitor that 2 tracks (L & R assume) are actually started and played but have the high volume distortion as mentioned and also seem to have some phase issues. I can correct the problem by converting the file to mono in an external program and importing.
Thank Mike!
We’ve been using SCS for many years now with good success!
Kendel
SM-S server: Cue Marker Triggers and Stereo Files
Re: SM-S server: Cue Marker Triggers and Stereo Files
Kendel,
Regarding item 2 in particular, please email me the SCS log file from a run in which this happened. Log files are created and saved in a folder named "SCS Logs" under "Documents", and the name of each file includes a time-stamp indicating when the log started.
