Maximum audio outs.
Eclipse
Maximum audio outs.
Post by Eclipse » Sun Nov 14, 2021 8:45 am
I am running SCS Pro Plus, which the guide claims gives me 16 outputs per cue.
Is there any possibility of expanding that as eight stereo sends is insufficient for our needs?
Rob
Re: Maximum audio outs.
Post by Mike Daniell » Sun Nov 14, 2021 4:04 pm
The limit in SCS Professional Plus is 16 audio devices per cue, so provided you have set up these devices a 2-channel outputs then you should be able to have up to 16 stereo sends per cue. If this isn't being accepted then let me know.
Eclipse
Post by Eclipse » Wed Dec 22, 2021 2:35 am
This doesn't help me much because I am using a 64 channel desk (PreSonus X64S) which is effectively one device.
I really need around 12 stereo pairs as backing tracks.
Rob
Post by Mike Daniell » Wed Dec 22, 2021 8:28 am
Rob,
A log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started. Please email me the log file from a run in which you have the X64S connected and a cue file opened that you want to use.
Eclipse
Post by Eclipse » Mon Jan 17, 2022 1:27 am
Sorry it's taken a while to get back.
I went to create a log file as you requested and it seems all 64 channels are now showing up in SCS.
Probably pilot error on my part.
Best regards,
Rob
