[Mod 11.8.3.3] m4v files
Wilts20
Post by Wilts20 » Sun Nov 29, 2020 6:54 am
Is there a list of supported video file types anywhere? I have just started to use SCS to play video cues and have some .m4v files. If I drag them into the editor I get an error message say that they are not supported. However, given that they are basically just H264, if I rename them to be .mov files (ie just renaming, no conversion) then then load in and play fine.
Clearly a simple workaround but I was wondering whether I am missing a setting somewhere that would enable be just to drop and drag them in.
Cheers
Paul
Re: m4v files
Post by Mike Daniell » Sun Nov 29, 2020 2:45 pm
I've just run a test here using a couple of downloaded m4v (iTunes video) files, and the video playback library used by SCS does support this format, so I will add m4v support to SCS in the next release. The list of supported video file formats will then be "avi,wmv,asf,mpeg,mpg,mp4,mov,m4v,divx,mkv,flv,f4v,4fp,f4a,f4b,3gp,3g2,mts,m2ts,vob".
Wilts20
Re: m4v files
Post by Wilts20 » Mon Nov 30, 2020 5:08 am
IanH
Re: [Mod 11.8.3.3] m4v files
Post by IanH » Tue Jul 06, 2021 8:24 am
@Mike,
can you update the list of supported formats on your web page? https://www.showcuesystems.com/cms/features
Post by Mike Daniell » Tue Jul 06, 2021 8:56 am
Ian,
Will do. I'm considering dropping f4... as you had some major issues with an f4v file. Did you manage to get this resolved, apart from converting them to mp4?
