[Fix 11.8.1] Playback Cursor issue in Edit Window, SCS 11.8.0.1
Eric Snodgrass
Post by Eric Snodgrass » Sat Jan 26, 2019 12:51 pm
In SCS 11.8.0.1 I am putting together a new show. Three cues into it I have found a bug with the playback position cursor in the Edit Window.
Each cue is set to start at the -45db point. In the Edit Window I hit PLAY and the cue plays where the Start marker is placed. I stop playback and the playback cursor returns to the correct Start position. I go to the next cue in the Edit Window and do the same thing. Then, when I go back to a previous cue, the playback cursor is not at the Start marker of that cue, but is instead positioned well into the cue. This seems to affect each cue in the Edit Window.
This is repeatable. It doesn't appear to affect playback in the Playback window, although my testing has not been extensive.
I have attached a diagnostic file for you.
scs11diag_20190125_184239.scsz
(36.54 KiB) Downloaded 165 times
Eric Snodgrass
Re: Playback Cursor issue in Edit Window, SCS 11.8.0.1
Post by Eric Snodgrass » Sat Jan 26, 2019 1:24 pm
A quick update -
The playback cursor jumps AFTER I hit SAVE.
So, when I create a new cue and test playback in the Edit Window everything is fine. After I hit SAVE the playback cursor jumps ahead of the START marker in that cue and all previous cues. The playback cursor appears to jump to the exact point where I stopped the playback for that particular cue, AFTER I hit SAVE.
Post by Mike Daniell » Fri Feb 01, 2019 6:18 pm
Confirmed. Should have a fix for this soon.
