DMX master fader not working
allcomp
Post by allcomp » Fri Aug 31, 2018 6:52 am
Hi Mike
I can´t get any respons on lighting cues when using DMX master fader. I am using current version SCS 11.7.1.3
Brian
Re: DMX master fader not working
Post by Mike Daniell » Fri Aug 31, 2018 8:13 am
Tested here and it works OK. Could you email me a diagnostic file? You can create this file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
allcomp
Post by allcomp » Fri Aug 31, 2018 5:41 pm
Here you go.
Brian
scs11diag_20180831_093656.scsz
(20.32 KiB) Downloaded 54 times
Post by Mike Daniell » Fri Aug 31, 2018 6:17 pm
OK, I see the problem. The changes made in SCS 11.7.0 didn't handle the DMX Master Fader where no fixtures had been defined. I'll provide a fix for that early next week.
The next version of SCS will have further improvements to lighting devices and cues, including the specification of fixture types. We are preparing to use this new version in a production here in October and November, so if you'd like more info on this and the opportunity to try a pre-release, let me know.
allcomp
Post by allcomp » Fri Aug 31, 2018 8:28 pm
Thanks Mike.
I would very much like to try a pre-release with the new improvements.
Brian
