Can't select a cue for playback
Criterion_Earlsdon
Post by Criterion_Earlsdon » Fri Jan 26, 2018 3:18 am
Hi Mike, I was trying to play cue QB, in rehearsal mode. Whenever I clicked on it, the highlighting stepped up to QA so I couldn't play it. I'm sure I've had this before. I think that, both times, I had added a cue to the top of the show, which may be relevant.
It's working fine now, probably after restarting SCS, which fixes most of my glitches :)
Diagnostic file attached. Note that the forum wouldn't let me upload a .scsz file so I've changed it to .txt to get it to you!
Thanks, Dave
scs11diag_2018-01-21_183026.txt
(62.05 KiB) Downloaded 60 times
Re: Can't select a cue for playback
Post by Mike Daniell » Fri Jan 26, 2018 3:56 pm
Don't know why this would happen. I note that QA is a time-based cue, but I presume you changed the time profile to 'Rehearsal' before trying to play cue QB. Unfortunately changes to the selected time profile are not recorded in the diagnostic file. But you say that restarting SCS fixed the problem. So what was different between the two runs (up to that point)?
Criterion_Earlsdon
Post by Criterion_Earlsdon » Sat Feb 03, 2018 11:28 am
Thanks for your prompt response Mike. Unfortunately I have no further information. When it occurred I was too keen to get the cue played to get the rehearsal underway, to note down any more details, sorry.
