[Fix 11.6.2] Image resize bug
Post by Buyaicia » Thu May 25, 2017 2:56 am
SCS 11.6.1
I cannot resize images. If I move the size slider the values shown change but the image not.
With videos I have a diferent behavior, I can make it bigger but not smaller.
Fenrise
Re: Image resize bug
Post by Fenrise » Mon May 29, 2017 7:51 pm
Same problem here,
After upgrading theater SCS from 11.4 to 11.6.1 all video/image cues starts to ignore position and size settings. Image cues can be moved, resize is not working. Video cues ignore all settings except aspect ratio. Plus resize slider is inverted (up to shrink, down to enlarge). After SCS upgrade, xVideo codec disappeared from Video settings, only DirectShow and TVGrabber is avalible.
LAV filters installed.
Projector Panasonic EZ570 using Lindy HDMI extender over ethernet cable. On older versions of SCS works flawlessly.
scs11diag_2017-05-29_122247.7z
(12.62 KiB) Downloaded 54 times
Post by Mike Daniell » Tue May 30, 2017 8:00 am
This will be fixed in 11.6.2. I've emailed you details of a pre-release.
