SCS 11.5.3 Available
Locked
Post by Mike Daniell » Tue Jan 17, 2017 10:31 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months *) may now download SCS 11.5.3 from the Download page of the Member Area.
* This is a bug-fix version only so the download eligibility date has been backdated to the release date of 11.5.0 (28 June 2016). If 11.5.3 is not available on your download page, try the download archive.
Important: If you are using TVG as the Video Playback Library in SCS then we now recommend you download and install LAV Filters. See 'New or changed features' below for more info.
Bugs fixed in SCS 11.5.3
  • If a Video Cue is set to 'pause at end' and also has a sub-cue fade-out time, then the video would fade-out before the pause, even though the cue was not about to complete. The fade-out time is now ignored and the video remains fully displayed until the cue is closed.
  • Some fixes have been applied in the interface between SCS and SoundMan-Server (SM-S). As from SCS 11.5.3, SM-S users should ensure they are using SM-S 1.0.110.0 or later.
  • MTC (MIDI Time Code) cues could lock-up for a few seconds if the MTC display is in a separate window.
  • 'Stop Everything' would not stop MTC cues under certain conditions.
  • In some rare circumstances, the TVG primary screen has been found to be a different screen to the SCS primary screen, which resulted in video images being displayed on the wrong screen. SCS now compensates for any such discrepancy.
  • When cross-fading a video, the final image of the faded-out video could become visible briefly when the faded-in video completes.
  • Incoming network messages from a PJ-Net Control Send device were not processed due to an incorrect 'fix' applied in an earlier version of 11.5.2.
  • When setting up a Lighting Device in Production Properties, an error could occur in 'set enabled' if your license level is SCS Professional.
New or changed features in SCS 11.5.3
  • A newer version of the TVideoGrabber (TVG) library is included, but for this version we recommend you install the LAV Filters package rather than FFDSHOW. LAV Filters is easier to install if you follow the instructions in the SCS Help file under Options and Settings / Video Driver. We have found that some MP4 files do not play using FFDSHOW but no issues have been found with any files when using LAV Filters. LAV Filters can be downloaded from https://github.com/Nevcairiel/LAVFilters/releases. As mentioned in the SCS 11.5.3 Help we recommend you download latest Installer.exe file (eg LAVFilters-0.69-Installer.exe) as running this executable is the easiest way to install the package, and by default will install both the 32-bit and the 64-bit versions. In the Select Components window of the Setup dialog, make sure you have at least all the LAV... checkboxes selected (which they should be by default).
Locked
