OS: Windows 10
Sound Card: Xonar U7
Recently I upgraded to version 11.5.2.3 and discovered that the software would only send out one mono channel when when I used a configuration that used all 8 channels of the Xonar U7. It had been previously working with an earlier version of the SCS software. When I returned to version 11.5.1 all 8 channels worked completely.
I _had_ tested all the channels on the Xonar U7 by using the Sound Control Panel. I could hear each of the channels with no problem. It was only accessing them through SCS that was problematic.
NO SARCASM: thanks for wonderful software that we use all the time. I love this program and I am glad you keep earlier versions online - in case something like this happens. I hope this is an easy fix for you.
Bill Ritch - president of the Atlanta Radio Theatre Company (www.artc.org).
[11.5.2.3]-Not using all channels of hardware Xonar U7
Re: [11.5.2.3]-Not using all channels of hardware Xonar U7
Could you email me diagnostic files created under 11.5.2.3 and also 11.5.1? You can create these files by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
I shall do that. I had taken some time off from SFX after our Halloween show.
