New and Changed Features in SCS 11.5.1
- Collect Production Files now includes an option to export the Device Map File. This can then be used, if required, when setting up the production on another computer if the other computer has the same or similar devices. You can now also choose not to switch to the 'collected files' folder which is useful if you are using the function to create a back-up or to transfer the production to another computer using an external or network drive.
- Added the ability to create Place Holders for Playlist Cues where you do not have (or have not decided on) the required files.
- Added an Editing Option to Display all MIDI input messages when the Editor is active. MIDI input messages that are not needed are normally filtered out immediately, but if you want to see these messages in the status line (or test window) then select this option. This ONLY applies while the Editor is open.
- Cue Control by DMX was unintentionally disabled in 11.5.0. Now re-enabled.
- Starting Video Cues in the Editor when the progress slider had been moved from the start position would not start playback from that position when the video playback libary was TVG.
- In the Editor, changing the cue number and then immediately clicking Save could throw a 'sanity check' error if that cue is referred to by another cue (eg by an SFR cue).
- A cue set to auto-start after the end of another cue may have not auto-started if the run mode is non-linear.
- Fixed some issues with free-format OSC messages in 11.5.0.
- Activating a Set Position Cue from an incoming cue control message (such as a network message) could cause a thread assertion error.
