SCS 11.3.6 Available
Locked
Post by Mike Daniell » Mon Dec 08, 2014 10:29 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.3.6 from the Members' Download page.
Changes in SCS 11.3.6
  • A new Editing Option has been added: 'Save' button always enabled. When this option is set, you will always be able to save your cue file, even if no changes have been made or registered.
  • A new Editing Option has been added: Ignore File Title Tags when setting Default Descriptions. When this option is set, when you add or change an audio file sub-cue then the sub-cue description will always be derived from the file name, and will ignore the 'title' tag if present.
  • On all SCS sliders (faders, pan controls, progress sliders, etc) you can now use the mouse wheel to make adjustments provided the slider currently has focus.
  • The use of Shift+F11/F12 for adjusting levels of all devices in playing cues has been extended to include Playlist Cues. The adjustments in Playlist Cues are applied to the relative level of the currently-playing track.
  • An updated version of the French translation is now included (thanks to Michel Winogradoff), and of the Catalan translation (thanks to Lluís Vilarrasa).
  • Level changes that occur at the same time as cue panels are being refreshed are now smoother.
  • Fixed an error that could cause SCS to freeze when building an audio file graph in the Editor.
  • Fixed a few other errors.
Coming soon...
The next major release will be SCS 11.4.0 which will include a new video playback library providing considerably improved video and still image functionality.
Locked
