Changes in SCS 11.3.4
- Reduced the priority of the MTC thread to prevent audio glitches that may occur in some systems. (This only applies to productions with MTC cues.)
- Modified SCS to detect loss or reinstatement of a secondary screen, and to attempt to recover from this situation. For more info see Trouble Shooting / Video Problems / Loss or reinstatement of a secondary screen in the Help.
- Added an Editing Option to allow the generation of the Audio Graph to be bypassed if the Audio File is greater than a specified length (default 10 minutes).
- In Audio File Cues and Level Change Cues you can now use the keyboard shortcuts to increase or decrease the levels of all selected devices. See Options and Settings - Shortcuts for more info.
- The default keyboard shortcuts for Decrease Levels of Playing Cues and Increase Levels of Playing Cues have been changed from < and > to Shift+F11 and Shift+F12. This is because these shortcuts are now also available in the Editor for Audio File Cues and Level Change Cues, and characters like < and > may be required in text fields such as the Description.
- 'Save Settings (all Cues)' can now be accessed by a keyboard shortcut. The default shortcut for this menu item is Shift+F10.
- Fixed a few errors.
