I've been messing about with theatre sound for many years but I'm new to SCS.
Is there any way to automatically set up a mix from one audio cue to the next? Specifically, I want to mix from a running loop to the next cue?
I'm presently doing this by setting a Fade Out on the loop and a Fade In on the next cue to the same length then "double tapping" my space bar. However I suspect I'm missing something easy here--but when I enter "cross fade" or "mix" in the search engine I get references to cross fading video.
Thanks in advance for your help.
Bob
Mix to Next Cue
Re: Mix to Next Cue
Yes, you can set up a mix from one audio cue to the next. The key is to add an SFR sub-cue to your second cue to fade-out and stop the first cue. Here's an example using a 2-second cross-fade:
Q1: Audio file cue with fade-out time of 2 seconds.
Q2: Audio file cue with fade-in time of 2 seconds, plus an SFR sub-cue to 'fade out and stop previous cue'.
While Q1 is playing you can now press 'GO' (or equivalent) to start Q2. This will start the fade-in of Q2 and will also activate the SFR sub-cue to fade-out and stop Q1. So this provides a cross-fade from Q1 to Q2 with just a single 'GO'.
Re: Mix to Next Cue
Perfect!
That's effectively what I was doing except I tried to be my own sub cue!
Thanks!
Thanks!
Re: Mix to Next Cue
Sub cues are good tools.Bob Howes wrote:Perfect!
Thanks!
So are delayed cues.
