Import Device map?
QRS_Krister
Import Device map?
Post by QRS_Krister » Tue Jul 15, 2014 7:51 pm
Hello.
New user of this program.
Today I run tree different shows using SCS.
Audio and Midi Control out (for light)
And I use "MIDI IN" to Control SCS.
I can´t find any way to import device Map to new Project file.
when I open new projekt it start with default soundcard.
I change the computer do to hardware failure, and had to reprogram Midi Control for every projekt file :(
How do I import / recall device maps from different Project?
Anyone have an solution?
/Krister
(Sorry for my bad English text, live and Word in Sweden)
Re: Import Device map?
Post by Mike Daniell » Wed Jul 16, 2014 2:38 pm
Krister,
Currently there's no facility for importing a device map, but a commonly-used solution to this issue is to have a dummy cue file that contains the device selections and properties that you frequently use. Then when you want to create a new production you just need to open this dummy cue file and immediately 'save as' your required new file name. You new production will inherit the same device map settings you have in the dummy, and you can use these as is or modify them to suit your new production. Another benefit in having this dummy cue file is that you can include some cues (eg hotkey cues) that you may frequently need.
