hi
i have a 6 channel multitrack wav file 44.1 32bit stereo (backingtrack on 1,2, then vocals on 3,4)
i would like scs to play to 4 outputs of the sound card
i have a trust audio external usb soundcard http://www.trust.com/en/all-products/14 ... sound-card
i can get audio out of the 4 outputs - if i play separate audio files - some routed to outputs 1,2 and other audio files routed to outputs 3,4
running scs standard ver 11.2.6
multichannel audio playback
Re: multichannel audio playback
From what I can see of that device, you should be able to select 6 channels for your output device under 'Channels Required' in Production Properties - Audio Output Devices.
If that doesn't help, could you email me a diagnostic dump file? You can create this file by starting SCS and selecting 'Create Diagnostic Dump File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Dumps" under "Documents" or "My Documents".
