Hello!
I'm using SCS 10.9.7 and I have a question regarding using a MIDI Send cue to send multiple control messages.
First off, equipment being used:
ETC Ion (connected via MIDI to SCS)
SCS 10.9.7
M-Audio MIDISport 1x1 Interface (connecting the Ion to SCS)
I am using MSC GO messages to control cue lists and MSC FIRE messages to control macros on the Ion (which releases a specified cue stack). Some MIDI Send cues run all control messages, while some only run the first message in the list. I'm pretty certain I have all my MSC messages pointing to the right cue lists/macros and are correctly formatted.
Example:
Cue "Normal Lighting" sends
-Sends MSC GO to run cue list 1/1
-Sends MSC FIRE to run macros on Ion to bring down all other cue stacks
Cue "Shields Up" sends (yes this is involving spaceships...)
-Sends MSC GO to run cue list 2/1
Cue "Docking" sends
-Sends MSC GO to run cue list 3/1
So, when I run the "Normal Lighting" and then "Shields Up," I get what I want. Then when I run "Normal Lighting" again, nothing happens. The shield lighting is supposed to come down and leave only the 1/1 cue running. But then when I go back to "Shields Up" (which works, as it only runs another cue, so the lights come up as I want) and run the "Docking," it gives me the results I want, which is that the macros have run to bring out all cue lists and the 3/1 cue has been run.
I know this is not a problem between the Ion and the dimmers as I've double checked the macros and cue lists between there. SCS says it fires all the control messages, and when I test each message individually, they work. But when I run the entire MIDI Send cue, it doesn't.
Thoughts? Why is one MIDI Send cue actually executing the entire control message list while another is only running the first?
Multiple MIDI control message problems
Re: Multiple MIDI control message problems
When you say that you run "Normal Lighting" again, is this a duplicate of the original cue or are you using a hot key cue for this?
Could you email me your cue file (the .scsq file) and also a screenshot of the "MIDI Devices & Control" tab under Permanent Options?
