[Fix 11.1.4] Delayed Auto-start audio file not playing...
Ian Wright
Post by Ian Wright » Sat Nov 03, 2012 9:01 am
Showfile created in version 11.1.2 exhibited this bug. Bug still there testing same file in 11.1.3
Q1 is a pre-show playlist
Q2 is a manually triggered fade and hibernate cue for Q1
Q3 is a pre-show announcement set to autostart 3 seconds after end of Q2
Q4 ..... other manually triggered cues
When Show Cue System is started the cues execute as expected for the first time. However if I break out of the show part way through with ESC and go back and restart at Q1, Q2 runs OK then Q3 runs the 3 second countdown but the audio file doesn't start to play. Pressing spacebar at this point will trigger Q4 and subsequent manual cues OK.
I got round the 'bug' by setting the Go next manual cue option on Q2 with a time delay which did work consistently
[Tried to attach dump file but got error message that extension dmp is not allowed]
Ian
Re: Delayed Auto-start audio file not playing after first ti
Post by Mike Daniell » Sat Nov 03, 2012 2:46 pm
Fix ready for next version (11.1.4 or 11.2.0).
