11.1.2
For a band I started by entering all songs as "Note Cue"s to get a set list then started filling in the click tracks, samples and video.
In my original tests (eval version) everything worked fine when I built song cues, but not in the licensed version. It took some playing to realize that when I added cues and the initial "Note" became the first sub-cue then anything that was based on an offset would not work. If the sub-cue was set to start immediately then then it executed but most of the video was delayed from the start of the click track/audio cues so it wouldn't start.
A "fix" isn't necessarily needed but it should at least be a footnote that you can't have delayed sub-cues with a note.
Jay
[Fix 11.1.4] Timed sub-cues not working if first sub-cue...
Re: Timed sub-cues not working if first sub-cue is a note
Fix ready for next release.
