Mike, I am using SCS 11.1, and have two playlists in my show that I have the Repeat check box checked. In playback, when it gets to the last song, it shows "Repeat", but it also shows a "P/L remain" countdown. When the last song completes, it does not repeat from the beginning, but rather it just appears to load the first song in the playlist, and stops. It doesn't clear the playlist from the screen (as it would if it was completed), so the next GO restarts the playlist from the top. However, if I do a SFR fadeout before completion, the fadeout work fine, and releases the playlist.
I'm running on a Windows XP (32-bit) system. Let me know if you need any more info.
Thanks! (It's been a long time since I've posted!)
SCS 11.1 Playlist Repeat not working (fix in 11.1.1)
Dan Virtue
Community Players Theatre
Bloomington, Illinois
Re: SCS 11.1 Playlist Repeat not working
Dan,
You should find this fixed in SCS 11.1.1 RC2, which I've just uploaded.
Thanks Mike!
Dan Virtue
