SCS 10.8.0 and uninstalling earlier version
runawaymartin
Post by runawaymartin » Thu Jun 16, 2011 9:03 am
Hi Mike . . . great news re the release of 10.8.0.
If you decide to change over to SCS 10.8 you should uninstall the application 'Sound Cue System', but don't do that yet until after you have run SCS 10.8 at least once so that 10.8 can pick up the registry settings saved by your earlier version.
. . . . I'm just wondering what are the implications if previous versions are not uninstalled?
Cheers . . . Martin
Martin Norris
Sound Achievements P/L
Runaway Bay, Qld, Australia
Re: SCS 10.8.0 Available
Post by Mike Daniell » Thu Jun 16, 2011 9:38 am
No problems - if necessary you should be able to continue to run 10.7 (or earlier) even with 10.8 installed. You will, however, find your .scs files are now associated with 10.8 so if you double-click a .scs file, Windows should open that file with 10.8. The only reason to uninstall 10.7 (ie uninstall 'Sound Cue System') is to clean up your machine when you no longer need to use 10.7.
