SCS 10.6.2 now available
Post by Mike Daniell » Sat Dec 12, 2009 9:04 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 10.6.2 from the Members' Download page.
The following changes are included in 10.6.2:
  • Improved the handling of sound devices changes in the Production Properties. See Production Properties in the Help for details.
  • The drop-down list 'Speakers/Outputs' in the Production Properties Sound Devices tab now contains only speakers/outputs available for the selected physical device. Previously the drop-down list contained all possible speakers/outputs, whether or not they were available for the selected device.
  • When not using the internal mixer, stereo audio files are now downmixed to mono if played to a mono output. Previously only MP3 files were downmixed, and other types would throw the error 'unavailable speaker'.
  • With MIDI Control Send cues, SCS now checks for 'MIDI not ready' return codes and will resend a MIDI message if this return code is received. This is to handle situations where a MIDI device has been swamped and is temporarily blocking incoming messages. SCS will keep trying to send the message for up to 1 second.
  • In a Control Send cue you can now select 'MIDI Free Format' which provides a free-format way of entering any MIDI message, including MMC (MIDI Machine Control) messages.
  • Auto-scrolling of the cue list in the main window now keeps the 'next cue' visible in the middle of the list or higher, even if a running cue needs to be scrolled off the top. Auto-scrolling is disabled if you manually scroll the list while a cue is running, and is re-enabled when the earliest running cue completes.
  • ASIO support now added for SCS Standard users. Previously, ASIO support was only available for SCS Professional and Professional Plus users.
  • SCS now ignores non-WDM, non-ASIO devices, such as the "Modem #0 Line Playback (emulated)" device.
  • Fixed various errors.
