Hi
Have a small problem getting the audio track of a video to play through the xUSB driver. All audio cues play to assigned ouputs but audio from video doesn't. And for some reason VLC no longer outputs audio to the default output. Totally baffled. Any thoughts?
EDIT System is i7 Quad, 8GB ram, 2 x HD3450.
Lindsay G
SCS 11.4.1, X32 USB and video
Re: SCS 11.4.1, X32 USB and video
Do you have the Video Playback Library in SCS set to TVG? I've just run a test here and video audio plays back through the X32 perfectly.
If you still can't get this to work after checking the Video Playback Library, could you email me a diagnostic file? You can create this file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
Hi Mike
I'll double check. Fairly sure it was set for X32. I will run a diagnostic today.
It seems another problem has developed with this particular computer that may be related to the HDD. It apparently takes a while to save edits to the show file but that's for another thread
Cheers
LindsayG
Cheers
LindsayG
TVG didn't want to work for some reason. Did a work around to get show up on time. Will play with this once show closes to see where I was going wrong.
Update: Still had old Audigy card in and Creative ASIO drivers were causing all sorts of havoc. Sorted now.
