How do you play a MIDI file as a control send
My pyrotechnics system runs off of MIDI note on messages. I have shows that are programmed to music and saved as a .mid (MIDI file). How do I play these so that they send out on the MIDI control send device? I thought this was in SCS10 but can't find it in SCS11 or find information on it.
Re: How do you play a MIDI file as a control send
Specific info on this seems to have get left out of the Help file, but what you need to do is this:
- In Production Properties (in the Editor) select Devices / Control Send Devices and set up your required MIDI Out device.
- Then add a Control Send cue and set the Message Type to MIDI File. Click the Browse button (...) to locate the MIDI file.
Well I looked right over it. I thought I had read something about it being moved to the midi cues. Thanks a million Mike.
