Waveform in editor (in 9.5.0 / 10.1.0)
I am currently teching a show which uses a lot of music for transitions, which means I only really use about a minute of the songs but I don't want to edit them down. I am also running this on an older box; P3 256mb ram. This causes a problem when trying to quickly run through the editor. I constantly have to wait for the waveform to reload or else I risk freezing the system.
All that setup, now here is my request. Could there be an option to turn the graph off by default but add a button where the graph would be to turn it on temporarily until we change the screen? It would greatly help performance on slower machines.
Let me know if that doesn't make sense. I just got out of a very stressful rehearsal.
eric
eric
I agree with this one also. In experimenting with putting our current show on SCS, I have a 40 minute rain storm track and 10 minute wind track. When I pulled up the 40 minute track and nothing displayed, I wasn't sure if the editor had hung ... so an indicator there would be useful. And the 10 minute track does take a bit of time to display.
Mike, if you could provide an option to allow us to specify the length limit, above which you would display an activation icon in big black region where the wave form usually sits, that would probably do the trick and provide flexibility and be most intuitive for the users.
Thanks. John
Thanks. John
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
showing waveform
Hi
i too am experiencing this delay - yet when i use gold wave on the same machine it is not such a problem - i think this program saves the 'display' in some way after initial scan (presumably with some info to check if the source file is dirty). would this have the potential to speed things up and keep the display?
just a thought
TLG
just a thought
TLG
Re: showing waveform
Found an example of a peak file algorithm:
http://www.codeproject.com/audio/waveedit.asp
Might help also:
http://www.dsprelated.com/showmessage/31617/1.php
Greetings,
Walter
Might help also:
Greetings,
Walter
