[In 11.3.0] Large Midi Timecode Display Window
It would be very comfortable and helpful for many productions, if the MTC could be shown in a separate window on a second computer graphic output.
Re: Large Midi Timecode Display Window
I am a very satisfied user of SCS. We use it mostly for dance performances in our theater.
We play music with SCS and cue the presets in the lighting console.
A major problem is to see the little counter / clock because it is so small
Therefore, it is my wish that in a newer version if it is possible to get a frame or a window that is larger for the clock.
with best regards
Manne Egenaes
Kulturumteatern
Märsta, Sweden
with best regards
Manne Egenaes
Kulturumteatern
Märsta, Sweden
You can set up the visual warning:Manne wrote: A major problem is to see the little counter / clock because it is so small
Märsta, Sweden
Click Editor
Click Production
Click Production Properties
Select Run Time Settings tab
Select"Count UP Whole cue" at "Give Visual Warning"
Select "Time Format" at "Visual Warning Display Format"
May be this is what you want.
- BigTime.PNG (98.79 KiB) Viewed 840 times
Hello
Thanks for the tip. Just what I was looking for.
/Manne
/Manne
Hi Mike!
11.3.0 RC7 is exactly what I meant! Thank you very much! Great!
Regards
Frank
Regards
Frank
