[In 11.9.1] Fade All option for MIDI program change
kevinmcdonough
Post by kevinmcdonough » Fri May 06, 2022 9:17 am
hey all
Setting up a USB Go Box for the first time. I quickly learned that SCS only works with a very small set of Midi Show Control commands, and I was only able to use two of the buttons on the box in that mode.
I changed the mode of the box to send program control messages instead, and after a few minutes of faffing was able to set almost all of the buttons the way I wanted (Green: Go, Red: Stop All, the arrows: up and down the list, blue: play/pause).
The only thing I would like to add is to have the yellow button as a Fade All command, but unfortunately that option isn't available. Would it be possible to add this to the list of options for MIDI program change.
Thanks as always,
Kev
Re: Fade All option for MIDI program change
Post by Mike Daniell » Fri May 06, 2022 10:55 am
Kev,
I've emailed you a request for more info.
kevinmcdonough
Post by kevinmcdonough » Fri May 06, 2022 6:07 pm
Thank you for your quick response, have replied via email :)
Re: [Mod 11.9.1] Fade All option for MIDI program change
Post by Mike Daniell » Mon May 09, 2022 2:48 pm
SCS 11.9.1 supports mapping a MIDI command to 'Fade All' in Production Properties / MIDI Cue Control Devices.
