[Fix 11.8.3.2] Shortcuts [11.8.3.1]
Falko Heidemann
Post by Falko Heidemann » Thu Aug 27, 2020 6:43 am
I found some bugs by using the shortcuts.
Creating a marker by Shortcut (F7) only works when cue is playing. it dosent work when the cue is stopt and the nowpointer is manual set.
At the end of the shortcut menü, from "Tab Delay", the selectet Function is not right.
Tab Delay / Selctet Function = empty
DMX Master Fader Down / Selctet Function = empty
DMX Master Fader Up / Selctet Function = Tab Delay
DMX Master Fader Reset / Selctet Function = DMX Master Fader Down
Skip to previous Cue Marker / Selctet Function = DMX Master Fader Up
Skip to next Cue Marker / Selctet Function = DMX Master Fader Reset
This means that the corresponding shortcuts cannot be changed correctly.
Best regards
Falko
Re: Shortcuts [11.8.3.1]
Post by Mike Daniell » Thu Aug 27, 2020 11:24 am
That was intentional, but I'll have another look into the possibility of allowing F7 to create a cue marker at the currently-paused position.
I was aware of this in an earlier release and thought it had been fixed. The shortcuts are correctly displayed when I run it here. Can you email me a log file from a run in which these shortcuts are incorrect? A log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started.
