Hi There,
I cant seem to setup SCS 11.6.1 x64 as whenever i try to assign a audio device or Cue Control device, SCS will crash.
The screenshot of the error and the diagnostics file can be found here: https://www.dropbox.com/sh/u0v33yz78d4f ... Hlzwa?dl=0
If i click on Production Properties -> devices -> audio output
Add a new device name, when i click on channels required the app instantly crashes.
Same if i go Production Properties -> devices -> Cue Control.
If i select any of the options, the app will crash again with the same mmedia.pbi
This is regardless of if i use the demo show or if i create a new show.
Any help would be of great assistance!
[Fix 11.6.2] Crash on device setup
Re: Crash on device setup
Look here:
http://www.showcuesystems.com/forum/vie ... f=1&t=2599
This could fix this problem.
Look here:
Thanks for the reply,
The Release Candidate fixed the issue.
Hey, I can not view the link you posted. Could you actually post the answer to the question please?Buyaicia wrote:Hi,
Look here:
That topic and posting has been archived as it referred to a release candidate for SCS 11.6.2, which has since been fully released. So this bug is fixed in SCS 11.6.2. Are you using this latest release?vet873 wrote:Hey, I can not view the link you posted. Could you actually post the answer to the question please?
