[Resolved] DMX universe selection
Post by Boswell » Sat Dec 03, 2016 12:20 am
Hi Mike
Using a ENTTEC USB Pro Mk2, SCS 11.5.2.2 (x64), Pro Plus
Any DMX command I send on DMx1 is also sent on DMX2 and vice versa
Any thoughts?
Diagnostic & Cue file attached
Test.zip
(4.75 KiB) Downloaded 50 times
Re: DMX universe selection
Post by Mike Daniell » Sat Dec 03, 2016 8:51 am
I'll email you a tracing version that will trace what DMX values are being sent. I've run your cue file here and it works correctly - sending DMX value 13 (=5%) to channel 1 on port 1, and sending what SCS deems to be the current values (all 0) to all other channels on port 1 and to all channels on port 2. If I insert an extra cue before your cue, to send values to a couple of channels on port 2, then this also works correctly, and then when your cue is played it sends 13 to channel 1 on port 1, and re-sends the latest values (from my inserted cue) to the channels on port 2.
Post by Boswell » Tue Dec 13, 2016 3:05 am
Problem solved!!
Faulty breakout cable with the Enttec, replaced and then faulty operator action when testing! (ie me)
No faults with SCS at all and many thanks to Mike for his help and patience
