Post
by djvomght » Mon May 09, 2016 10:30 pm
Hallo at all,
during our last production, where the director loved to pick short snippets out of longer pieces of music and have them looped over minutes
I run into the following problem: If a fadeout or levelchange crosses the loop boarders of a loop having crossfades you'll get funny jumps of the level of the playing cue. I put together a test show to illustrate the problem, see the attachment of this post.
Best regards
Jörg
- looptest.zip
- (224.71 KiB) Downloaded 63 times
Post
by Mike Daniell » Tue May 10, 2016 8:56 pm
Which audio driver do you have selected? DirectSound or ASIO?
Post
by djvomght » Wed May 11, 2016 12:07 am
Hallo Mike,
the problem exists with both drivers, on different computers, with different audio hardware and with different versions of SCS.
Regards Jörg
ctcarter
Post
by ctcarter » Mon Oct 31, 2016 4:43 pm
I am also having this same problem; ver. 11.4.2.3. I am looping a short 7 sec drum cadence, and then want to fire a level change cue that lasts 20 sec. When the audio cue reaches the loop, the level change cue stops and the level remains where it was at when the audio cue looped. The audio cue has a very short (.02 sec) crossfade just to clean up the loop. When I remove the crossfade from the looping cue, the level change over 20 seconds works fine.
-ctc
Post
by Mike Daniell » Mon Oct 31, 2016 6:33 pm
ctcarter wrote:I am also having this same problem; ver. 11.4.2.3. I am looping a short 7 sec drum cadence, and then want to fire a level change cue that lasts 20 sec. When the audio cue reaches the loop, the level change cue stops and the level remains where it was at when the audio cue looped. The audio cue has a very short (.02 sec) crossfade just to clean up the loop. When I remove the crossfade from the looping cue, the level change over 20 seconds works fine.
-ctc
This bug was fixed in SCS 11.5.0. I've emailed you further information.
ctcarter
Post
by ctcarter » Mon Oct 31, 2016 11:16 pm
Thanks so much for your quick reply and great customer service! Big fan of your software.
ctc
