[Fix11.4.2.2]Premature termination of Audio cues in 11.4.2.1
ronb999
Post by ronb999 » Tue Feb 23, 2016 3:45 am
Just downloaded 11.4.2.1 and started work on a new show When I have just one pair of output devices specified in the device map, everything works OK. When I add extra output devices, the cue comes to an abrupt stop several seconds before the planned fadeout. Reverted to 11.4.1.1 and everything was OK. Tried with an old show and same problem. I only have one pair of speakers on my office PC, but the show PC has 4 pairs of outlets. Never had any problems in the past. I have attached the SCS diagnostic files from 11.4.1.1 and 11.4.2.1.
Cheers
Ron Balmforth
maxcanis
Re: Premature termination of Audio cues in 11.4.2.1
Post by maxcanis » Tue Feb 23, 2016 4:17 am
I am experiencing the same issue with 11.4.2.1. I've rolled back to 11.4.2 and while it was better I could see that the scrubber would sometimes appear to hang up at the same point where it would terminate the cue in 11.4.2.1 so I rolled back further to 11.4.1.1 as the OP did and now it works as expected.
Martin
Post by Martin » Tue Feb 23, 2016 7:57 pm
Same problem here. It is intermittent and seemed more likely to occur when SCS was busy - eg playing cues while counting down multiple other sub-cues. I too have backed off to 11.4.1.1.
Post by Mike Daniell » Fri Feb 26, 2016 7:12 pm
I've now found and fixed the error, which I will release in 11.4.2.2 as soon as I've had confirmation from users I've emailed that this now works OK.
Post by Mike Daniell » Tue Mar 01, 2016 9:30 am
Fixed in 11.4.2.2.
