Slideshow not crossfading at loop.
russhart
Post by russhart » Wed Nov 18, 2015 7:04 pm
Using 11.4.1.1, setting up for a carols night. On a slide show at the end of the cue file, when it loops to restart from the first image, the last image doesn't crossfade, it just stops. The next image (first one in the slideshow) does fade in. I have a 2 second crossfade set, and no fade in or out times set on the image cue.
Re: Slideshow not crossfading at loop.
Post by Mike Daniell » Thu Nov 19, 2015 10:27 am
I've just run a test here and the crossfade from the last image back to the first image worked OK. Could you email me a diagnostic file? You can create this file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
