[Fix 11.2.4] SCS 11.2.3 device map bug
d_korman
Post by d_korman » Mon Sep 02, 2013 9:46 pm
HI Mike,
I have come across a problem where I cannot change the output device specified in an existing cue file. The scenario is as follows:
1) Open an existing cue file which has a device map that points to an ASIO device that is not currently connected to the PC
2) Receive the error message pop up that give the options to review/change device map, close cue file or close SCS
3) Elect to review/change device map, and the editor window opens in the production properties tab
4) Select a DirectSound output device that is connected and working
5) Applyt device changes - the icon doesnot grey out after applying the changes - this seems wrong.
6) send test tone - works OK
7) Try to save cue file - but save icon is greyed out
8.) Try to close editor - but get error message that says "you have unapplied device changes. Please apply or undo your device changes" - but I've already applied them and applying them again makes no difference - the Apply Device changes icon is still active. The only way out of the editor is to undo the changes!
9) Changing the device to another ASIO device that is connected and working is even worse - I get various different error messages that don't seem to be easily repeatable and eventually SCS crashes.
Dump file has been emailed to you.
DAve
Re: SCS 11.2.3 device map bug
Post by Mike Daniell » Thu Sep 05, 2013 9:59 pm
Fix ready for next release.
