[Resolved] Controling SCS on a different PC via network does not work
Greg
Post by Greg » Wed Nov 13, 2024 9:17 pm
I am trying out controling SCS on a different PC for our theater play next week. However the control command is not received.
I have verified that the UDP control command actually arrives at the other PC (using a echotool - see screenshot). Also SCS seems to open the correct UDP port because it complains when the echotool still blocks this port.
However, when i open the 'Test Network control...' window it stays empty and does not show control commands sent over. See second screenshot for configuration.
Anything I am doing wrong here?
Greg
echotool receives the UDP command
Screenshot 2024-11-13 121544.png (21.72 KiB) Viewed 9390 times
setup in SCS with no
Screenshot 2024-11-13 100250.png (83.52 KiB) Viewed 9390 times
dee99
Re: Controling SCS on a different PC via network does not work
Post by dee99 » Thu Nov 14, 2024 2:47 am
Hi, can you please send this information plus screen shots of the sending PC setup and the log files from a run where this fails please to support@showcuesystems.com. Log files can be found in your "documents\scs logs" folder".
Thank you, Dee.
LONGJOIN
Post by LONGJOIN » Thu Nov 14, 2024 11:19 am
What application do you use to send the encoded OSC messages? Have you tried sending ASCII messages? You can switch to view ASCII messages via the menu in the red circle below.
Greg
Post by Greg » Thu Nov 14, 2024 4:17 pm
Problem solved. The issue only seems to occur with the (expired) Demo version which otherwise seemed to work well (within the 5 min interval).
In the meantime i got an actual PLUS license. With this license this works now like a charm. :D
