Version SCS 11.9.3 (x64), Build 2022/07/01 09:50
I'm currently working on a showfile wich has a "just in case a mic explode on stage" playback track in it, since it's very rare that we use it, i commonly leave it on the "not enabled" status. I was cleaning some other stuff on the project and I noticed that the cue start anyway when I hit play (the trigger for playback is an autostart 0 sec after start of another cue).
I think the bug it's caused by the fact that the two cues are linked since the duration is the same, the trigger is simultaneous and SCS link them as it should (and i love him for doing that). I think he ignore the fact that the second one is disabled.
Road to reproduce the bug:
1. Create a SCS project with two audio cues linked (so need to be exact same duration)
2. Start them with a common trigger, like an auto-start (not as a sub-cue, this bug does not affect sub-cues)
3. Disable the second cue (the one with autostart)
4. Press play and verify that even the disabled one is playing
WORKAROUND
If anyone's got my same problem the workaround is setting the linked track as a sub-cue and not with a common trigger (like autostart after tot secs)
Thanks in advance for all your work, i hope that this report would be helpful for the community, i'm not a very active user here, but i love SCS and i'm very greatful that it exists.
[Fix 11.9.4] Linked Disabled Cue still playing
Re: Linked Disabled Cue still playing
Fixed in 11.9.4.
