I use this for a yearly Christmas program at church. I used 9.4.6 last year and everything went
fine. I was about to upgrade to 10.2.0, but looking at the forums, I see several problems with
10.2.0 mentioned - cues don't fade all the way, audio glitches, cues misfiring...
Are those just isolated problems or should I stay with 9.4.6? I wanted to upgrade for a few of
the MIDI improvements, but can live without them.
MX
Should I upgrade? (9.4.6 to 10.2.0)
Re: Should I upgrade? (9.4.6 to 10.2.0)
I'm planning to release 10.3.0 on Monday, which will fix all known problems. I've had several users running pre-release versions of 10.3 (and 10.2.1) and have received good reports from these users about the fixes.
10.3.0 will also have a feature to bulk edit cues. Initially this will provide bulk editing of audio levels (eg drop all levels by a specified dB); bulk editing of fade types, level change types, and the exclusive cue property. Other fields may be added later to the bulk edit screen.
Hi at all,
I'm just back from the last rehearsal of our new production, running 10.2.1 (tr) with more than 100 cues within 80 minutes. Everything is running flawlessly, so I encourage You to upgrade on monday. Having up to 10 control messages within one cue is very useful.
Regards Jörg
Regards Jörg
I'm glad I asked. I will get the update on Monday.
Thanks!
MX
Thanks!
MX
