demo - midi control send problem
Posted: Wed Nov 12, 2008 5:51 am
Hello, I'm a new user, currently playing with the demo to find out if SCS is the product for me... Having downloaded the demo, I've been trying to set up a sequence of "midi control send" cues to trigger cues on my lighting desk. The sequence is made up of "whole" cues, rather than being a set of subcues. Each cue auto runs at various timings after the start of cue 1.
At present, the sequence runs fine on my laptop, but only the first "midi control send" cue actually triggers a lighting cue. I have to restart SCS before another cue runs.
Likewise, if I open SCS and go into editor, select a midi cue, and use the "Test Control Send" button, the first time I do this a lighting cue will run fine, but no further cues will run, either using the test button, or by running the cue sequence... again, if I restart SCS, I can again run ONE initial SCS cue, but only one!
Is this a built-in limitation of the demo software? If not, can anyone suggst a solution?
Ben
Ben
