Cue fades only half-way, then stops... (fix in 10.3.0)
Posted: Fri Nov 07, 2008 4:25 am
by escrge
Using 10.2.0...
I have a wind cue that hibernates and resumes several times in a single act. The sound cue is set to fade up at 3.5 secs and fade out at 6 secs. The first two hibernation cues work perfectly. After that, every cue that calls for it to hibernate causes the cue to fade half-way, then holds for a moment, then cuts off. The resume cue, instead of fading up from -96, will start at the half-way mark where it cut off previously, then fade up to its set volume.
I have closed SCS and re-opened with no change and even moved from my designer laptop to the production PC with the same problem.
Re: Cue fades only half-way, then stops...
Posted: Fri Nov 07, 2008 6:24 am
by paul3263
I have recreated this problem myself but the fades are not as severe. In my version I start a Song a Q1 then Q2 – Q7 are Fade and Hibernate, and Resume to Fade in, alternately. The first fade goes smoothly to the end, Resume seems to jump, a fraction then fade up smoothly, next fade will stop about 2 dashes before the end not half way as in escrge’s version, and then stop, each Resume Jumps up fast then smoothly goes to full volume. There is something there causing a problem, in my version you would not notice it much sense it stops almost at the end but I can see how it would be problem to stop Half way, then drop out. I tried using the fade overrides, but no change.
Posted: Fri Nov 07, 2008 7:01 am
by escrge
Yes, I tried the fade overrides too with no difference. My jumps are very noticeable.
Posted: Fri Nov 07, 2008 12:48 pm
I've found the errors with the fade in and fade out of hibernated cues, and have emailed you both details of a fix to download.
Posted: Tue Nov 18, 2008 6:29 am
by Boswell
Using 10.2
I'm having the same sort of problem, Fade & Hibernate works the first time but resumes and later fade&hibernates just leave the volume at 0 even though the file is running. Changinging it to pause& hibernate and it works ok but it is then a bit abrupt!! :?
Can you please send me the fix Mike or is 10.2.1 on the way?
SCS file emailed to you.
Posted: Tue Nov 18, 2008 4:59 pm
Details of the fix emailed to you, Boswell.
Posted: Sat Nov 22, 2008 11:14 pm
by Boswell
Just to tidy things up, the fix works fine, all OK.
Thanks for the quick response Mike as usual :D
