Level change results in pan to 250500 (fix in 10.1.1)
Posted: Thu Aug 21, 2008 1:43 am
by escrge
I'm using 10.1.0.
I have a level-change subcue that lowers the level of a cue from -3 to -18. And for some reason, there's an unexpected pan to the right channel that's off the chart. In fact, on the upcoming level-change cue, the pan indicator isn't even in the indicator field. The value it's assigned is 250500. And no matter how many times I go back in and reassign the pan to CENTER, 501, or 499, the value always goes back to 250500 after I save and close the editor.
I deleted the subcue and started over from scratch, and that seemed to do the trick.
Thought I'd bring this to your attention.
Re: Level change results in unwanted pan to 250500
Posted: Thu Aug 21, 2008 11:53 am
Fix ready for 10.1.1. The error in 10.1.0 occurs if the pan text field is manually changed, but should be OK if you use the pan slider. The error only affects adding or editing a Level Change cue.
