Editing in Audition whilst running SCS (Fix in 9.4.5)
peterrice
Post by peterrice » Tue Sep 04, 2007 3:33 am
As I'm bulding cues I often want to change the .wav in some way. I open Audition, make the alteration and then try to save. Audition tells me the file is in use by another application and I must first close that to save. It can be very dull closing SCS evertime I want to make a .wav change is there anyway round this?
Peter Rice
Deputy Head of Sound
Royal Exchange Theatre
Manchester
M2 7DH
Post by Mike Daniell » Tue Sep 04, 2007 6:15 pm
You need to get SCS to close the file, and the easiest way to do this is to click further down the cue list so the cue with the file you are editing is 'completed'. If you are in the Editor you will probably need to close the Editor, but at least you don't have to close the whole program.
peterrice
That's what I thought...
Post by peterrice » Tue Sep 04, 2007 8:07 pm
I was going past the cue in the cuelist but not closing the editor. However closing the editor still doesn't seem to resolve the problem and the 'Status' reads as 'Completed' but I still get the 'File in use by another application' prompt in Audition. Any other ideas?
Peter Rice
Manchester
M2 7DH
Post by Mike Daniell » Tue Sep 04, 2007 10:40 pm
You're not using that same file in a later cue? I experimented with this here, using GoldWave to edit the file, and after clicking past the cue I could save the edited file with GoldWave, whereas when the cue was not 'Completed' I could not.
peterrice
The cue IS completed.
Post by peterrice » Wed Sep 05, 2007 11:22 pm
Yeah I'm trying to save when the 'End' cue is selected in the cue list (so everything is 'Completed') and it's still an issue. The editor window is also closed.
Peter Rice
Manchester
M2 7DH
Post by Mike Daniell » Thu Sep 06, 2007 1:11 pm
Peter,
I've emailed you details of a test I'd like you to run to help me work out why the files are not being closed when the cues are 'Completed'.
Jon Wiles
Post by Jon Wiles » Fri Sep 07, 2007 8:19 am
Hi mike
The same problem occurs with Soundforge 8. The window that pops up says
'An error occurred while saving one or more files. The file could not be created'
This occurs when the editor is closed, and the cue is either on the cue that is being edited, or a later one. Once SCS is closed, the file can be edited and saved
Post by Mike Daniell » Fri Sep 07, 2007 1:12 pm
Peter has emailed me the results of the test which has helped me track down the cause of files being left open. This will be fixed in the next release, but a pre-release is available for anyone who needs it now. (Registered users only.)
AndyT
Files left open
Post by AndyT » Tue Sep 11, 2007 4:02 am
Mike
Could this also be the cause of low virtual memory messages, where I didn't get these before upgrading to version 9.4.x? PC has 1GB ram and nothing else running (even unessential services disabled)
Cheers
Andy Terry
Post by Mike Daniell » Tue Sep 11, 2007 7:26 am
Could be, Andy. I've emailed you details of a pre-release of 9.4.5 to try to see if this fixes the 'low memory' message.
Post by Mike Daniell » Tue Sep 18, 2007 10:44 pm
The issue of some files being left open in SCS, even when the cue is 'completed', has been fixed in 9.4.5.
