ASIO Support?
Posted: Mon Aug 27, 2007 11:55 am
by SimnaWeb
I don't remember seeing you mention ASIO support, however, I had a very nice little surprise this evening. I recently bought a Edirol UA-1X USB Interface and it worked very nicely. It only gives 1 stereo pair, but its better than the onboard soundcard in my Dell Laptop. And the only drivers for it are the ASIO built in drivers.
Did I miss that announcement? Or just a pleasant surprise?
Posted: Mon Aug 27, 2007 1:22 pm
ASIO is not yet available in SCS so I expect something in the Edirol or Dell drivers is managing to play using the Windows WDM driver.
I'm working on a new major release of SCS and ASIO support is one of the features I am planning to include.
Posted: Mon Aug 27, 2007 9:35 pm
by SimnaWeb
Thanks for confirming I am not entirely crazy. I have a couple small events coming up in the next month or two and was thinking about using this. Would you trust it?
Eric
Posted: Tue Aug 28, 2007 12:52 pm
If you get good quality sound (checking with at least reasonably good speakers) then I'd expect everything to be OK. To provide better assurance, I suggest running a simulation of your shows / events. For example, run a cue list all the way through using the Edirol, and leave typically gaps between cues, so if in the show you are likely to have 15 minutes of non-SCS activity between two cues, then do the same in your simulation.
