Having serious problems with 9.2.6 and 9.1.5
drobkin
Post by drobkin » Fri Sep 29, 2006 12:04 pm
Hi Mike and community-
I am running SCS 9.2.6 on a Dell Inspiron laptop (4 weeks old) with 1 gig of memory and a 1.65 ghz processor. I am putting the signal through a Presonus Firebox firewire adaptor. There are about 85 cues in the show and we open on Saturday.
The software/hardware combo seems unable to output a clean signal. I am getting warbles and processing dropouts with every other cue. Any suggestions?
Dave
Post by Mike Daniell » Fri Sep 29, 2006 12:39 pm
Can you open Task Manager and let me know what CPU and VM Size is being used by SCS when you get drop-outs, etc? (You may need to add the column 'Virtual Memory Size' to the display as I don't think it is included by default.)
drobkin
Post by drobkin » Fri Sep 29, 2006 6:05 pm
Tomorrow, I've had to deal with lighting all night.
Dave
drobkin
Post by drobkin » Sat Sep 30, 2006 10:03 am
I did not find any information under "CPU" in Task Manager. It just read "00"
The VM was 118,960K
Peak Memory 115,500 K
Memory 69,000 K
Post by Mike Daniell » Sat Sep 30, 2006 2:04 pm
Doesn't appear to be anything unexpected there. I see from another thread that you may have ditched the Presonus. If so, is performance OK now?
drobkin
Post by drobkin » Sat Sep 30, 2006 5:04 pm
Yes. I went straight out of the headphone jackinto the mixer and the quality inproved.
I would still like ot use the presonus for another, multi-channel project, but that one is a long way off.
Any ideas about what makes the performance suffer through the firewire connection?
jsantroch
Post by jsantroch » Sun Oct 01, 2006 11:16 am
Was using an external Creative sound card with 8.5 and had similar problems until I went into control panel and disabled my onboard Inspiron sound card. That eliminated the instability I was getting while trying to use my external card.
Gary Matheson
Presonus Firebox
Post by Gary Matheson » Fri Oct 06, 2006 8:16 pm
Dave,
Have you since been able to sort out issues with the Presonus? I was considering buying one primarily for SCS purposes, but I am now wary. Should I avoid it?
Could other users out there with experience of using SCS on a laptop with an external soundcard/interface offer their recommendations?
Cheers,
Gary
Gary Matheson
Drama and Technical Theatre Applications Co-ordinator
singingdog
external audio card for laptop
Post by singingdog » Sat Oct 07, 2006 1:48 am
I've had good luck with the M-Audio firewire 410. Beyond all of its audio routing capabilities you also get two ch. of mic. pres and two headphone outs. -md.
jmgordon
Post by jmgordon » Sat Oct 07, 2006 3:47 am
It's most likely a Presonus/FireWire issue with your computer, and nothing to do with SCS.
Taking a look at the Presonus website support FAQs, there might be a Windows XP Sp2 issue, for other problems you might have to email them. I also have no problems with a M-Audio FireWire 410, but their website highlights a lot of possible issues with FireWire, including different versions of 1394 and the performance of different chipsets. You might have to go into Device Manager to determine exactly which FireWire chip and host controller you have in your Dell and follow up performance issues with Presonus.
drobkin
Presonus Boxes
Post by drobkin » Wed Oct 11, 2006 2:34 pm
I dumped the presonus box and went straight out of the headphone jack. I do not know what the firewire issues might be, but I had the same problems with an Intel IMAC running the 4-channel M-Audio box and Live!LE. I suspect it has to do with firewire settings etc, but I can't recommend the Presonus box at this time. When I get the computer back in 3 weeks I can give you more information, but I am thinking of returning it and buying the MacBookPro
