Enabled/Disabled Cues
ljc
Post by ljc » Thu Oct 24, 2024 11:56 am
Is it correct behavior that cues which are set to auto play do not play if the previous cue has been disabled? I need to have a playlist which is eventually stopped (after the current track is playing) and then a particular song is automatically played afterwards. This song can be preceded by another track which I would like to be able to enable/disable with a hotkey however, disabling this intermediary track means the final track is never triggered. Is there a way around this?
Re: Enabled/Disabled Cues
Post by Mike Daniell » Thu Oct 24, 2024 3:45 pm
Which version of SCS are you using?
